While the absurd movement this Urbie variant has might make you think "Long-range fire support", after some games, several million cbills, and a lot of fiddling about, I've found it also does great in the "Harraser" role Runs a bit hot if you try to duke it out with a proper light, so stick to your bigguns and pop from the left, the right, even poptart straight over your allies (may cause you to land on them, and worse, get in front of them just in time to sandwich yourself between their alpha and their targets alpha) BAP for GTFOECM action. could be dropped for an AMS, more MG ammo, or an extra heatsink and whatever else you can fit with half a ton The MGs are there so you have something to shoot while you're cooling down, so if you gotta shield, shield with the gun arm Yes I took points in the jump jet tree #noregrets
