_ Thanks to 20th april 2021 patch, 5xSRM4 no longer generate ghost heat. Not yet tested, but with max skills you should be able to melt anyone close range... Be careful on your own heat level, though. ALT: for the bravest and sneakiest warriors out there, you can fit an XL350 and 2xJJ for maximum flankiness _
If you have an XL375 lying around. _ It will be hot. You are going to have to limit to half you weapons after the second alpha.
