Casual TNS-HA "Shaken not Stirred" (3xLPL, 3xMRM10, ECM, LE300)
Thread in 'Hangover' started by S D, Apr 14, 2019.
  1. S D
    S D New Member
    I tried nearly every build on the site and hated this mech with a passion, until I stumbled upon this build. It is the perfect medium range fighter (for me). I consistently do between 500-800 damage per match. The LPLs deceive the enemy into rushing you, then they get pounded with the MRMs and don't know what to do.
    What I really love about this build is that it works with every single map. This is the best "jack of all trades" mech I've got. The weights didn't come out exactly right in mechlabs but you get the basic point.
  2. Shock
    873
    354
    This looks quite interesting. I'm going to have to try it. Moving the DHS into the engine and adding Light Ferro gives you enough to get AMS and more reasonable leg armor.
    S D likes this.
  3. CarloArmato
    35% cooling efficiency is damn hot with current meta.
    Also, consider that 1xMRM20 is slightly more heat efficient compared to 2xMRM10 + 1 DHS, but occupy less slots overall (3 slots instead of 2x2+3 = 7 slots)
    How about this one? I had to strip a bit mroe armor, but 5% gain in cooling efficiency seems worth it. Also, AMS is questionable due to the fact you already have lock on protection over ~270 meters
    If you are looking for even more weapon synergy, how about swapping LPL for regular LL?
    Regular LL have more range, weights less and have a longer cooldown + duration, but it's still much lower compared to MRM.
