TNS-5P "Surprisingly good" (1xGauss, 3xERLL, ECM, LE280)
4/5,
1 rating
Thread in 'TNS-5P' started by J S, Nov 16, 2017.
  1. J S
    J S New Member
    Although the weapons are mounted in the arms only, this build performs surprisingly well. Especially on Bubellite Oasis where you need to aim up and down a lot.
  2. Excalibaard
    5,262
    Great build indeed! The arms aren't that low, so it should also work in less vertical areas!
  3. Alloh_BR
    Alloh_BR Active Member
    Perfect name... doesn't look good but... it is!
  4. BrunoSSace
    BrunoSSace New Member
    Looks like a new build for FW for me. Like bringing my thannys to fw. The ECm really stumps all the Clam LRMers.
  5. CarloArmato
    If you take my advice, fit an XL325 for waaay better speed and acceleration, plus you don't lose so much heat efficiency (from 49% to 46%) and you can also fit a TC1
