    -- the MechSpecs team.
  2. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
Casual Tempest "Tube Shooter" (2xMRM40, 2xERML, ECM, LE275) +Alt
Discussion in 'Tempest' started by rinco, Nov 25, 2017.
  1. rinco
    rinco Active Member
    The Tempest is the most interesting of the Archer variants. Let's review:
    • Is the only variant with a laser cooldown quirk (albeit only -5% IS medium)
    • Has the best missile heat generation quirk at -10%
    • ECM
    So here is the first Tempest build that makes use of the new tech. It packs 2xMRM40 with 2xERML and I call it the Tube Shooter. Because it uses so many tubes, obviously.
    Edit: Here's an Alt build I have been running with 2xMRM40, 4xML, ECM and LE295. With Armor quirks and skills it's worth shaving a bit off the Arms and Legs. So far my field study suggests this is a winner...
    Matches Played: 10 (Solo QP)
    Wins: 6
    Losses: 4
    W/L Ratio: 1.5
    Kills: 11
    Deaths: 5
    K/D Ratio: 2.2
    Average Damage: 507
  2. Rosinante
    Rosinante Junior Member
    The MRM80 wearer has a good offensive quirk with 10% missile heat generation, while defensive strong armor quirks are available. The flaps, position of the cockpit and the relatively high cooldown of the MRM80, combined with the resulting "heat", make the Tempest not as easy to play as other 'Mechs. This variant has ECM, he is one of the few 'Mechs, which can carry it meaningful.
    dropped LaserĀ“s for higher Engine:
