I was browsing my mech list when I found out I wasn't playing this little boy since months, maybe years, since the warhammer became the new meta. After a quick look at the quirks and checking how it was fitted the last time, I've decided to go for the "All you can fit" And it does actually get a tons of quirks... And you are using all of them. Spoiler: Quirk list Energy Cooldown− 10 % Energy Heat− 5 % Energy Range+ 10 % Medium Pulse Laser Range+ 5 % Missile Cooldown− 15 % Base Structure (LT)+ 10 Base Structure (RT)+ 10 With the LE, you can actually fit anything it was intended to use, plus you have AMS and a fully armored left arm to shield with. If used properly and with the right skills, it should withstand some punishment. It should be very hot if you keep on firing every MPL all at once (so I recommend to ALWAYS use two groups separately), but you have excelent pin point damage and a little extra WOOSH from the SRM6 artemis
