Invasion TDR-5S-T Top Dog "The Pu(g)nisher" (3xLL, 4xERML, TC1, LE300)
Thread in 'Top Dog' started by CarloArmato, Jan 14, 2019.
  1. CarloArmato
    1,501
    446
    165
    https://mech.nav-alpha.com/#b46fcad9_TDR-5S-T
    It took a long time to figure out how to find the best vomit laser build on this chassis without having to fall back to my previous 5xERLL sniper version (which is still VERY valid despite being hot, though) or 2xLL + 6xERML... The trick was to actually fit a 3rd LL instead of a 5th and 6th ERML, so in the end I'm pretty confident I finally found the best vomit laser build to fully exploit slot layout and hardpoints.
    Anyway, classic vomit laser build with very high right side hard point and high to low hardpoints on the left side.
    Build has been built as symmetric as possible alpha-wise, but you can fit an asymmetric version to maximum exploit high hardpoints and to prevent losing the better LL compared to ERML if you plan to shield and lose your left side (despite LL being way worse when comparing DPS/damage to weight ratio)
    More asymmetric version (and moving 1 DHS from a wastable arm to a side torso is actually better):
    https://mech.nav-alpha.com/#ac26f1f8_TDR-5S-T
    Gun Tuv likes this.
