Hello everyone! I've been playing around with a 3 LLas in the left torso concept (as seen in my other build thread PUG Pony), and got something weird which I guessed I'd share. Not sure if it's viable (especially the XL engine makes the right side as being a shield less effective that I'd like) but I'll be happy to receive modification suggestions to the build. The LLas should be chain fired to avoid ghost heat, but still deal a respectable 9DMG/s. Obviously also possible with LBX10 if you're more of a close range fighter, strip armor with the LLs, shotgonne to the critical internals. I feel that with an AC10 you're able to stay more at range with full effectiveness. Then again the LBX has more DHS which puts the sustainability of chained LLas through the roof.
The LBX version was the second build I tried on this chassis. It was fun and seemed to work pretty well, but I have since moved on to other builds.
Obligatory update to a Light Engine. Stripped out two DHS and some left arm armor to get the LE275. I wouldn't miss the two DHS much because I think a heat efficiency over 40% is silly.
40% is actually on the low side if you've only got 13 DHS. Once you get up there, dissipation isn't enough to ever get you low again unless you take 30 seconds off from the fight
