TBR-A "Ebon Jag" (6xcERML, 2xcLPL)
1 rating
Thread in 'Warrant Builds' started by M3T4L R0N1N, Jun 22, 2018.
  1. M3T4L R0N1N
    M3T4L R0N1N Junior Member
    31
  2. Throet
    Throet Active Member
    Don't forget, this also has a fair bit more armor, but slightly less overall agility.
    Correction too, since the heat sink overhaul this fall, the heat efficiency is a bit better now too, as one additional heat sink here adds a full .22 dissipation.
    I'm not a fan of raw heat efficiency numbers, but this results in an increase of sustained DPS from 6 to 6.3.
    Also, I just realized this is doable with several of the other TBR chassis, notably any that have a CT laser hardpoint, as seen here with the -A:
  3. Throet
    Laser vomit got nerfed, but heat dissipation was subsequently buffed, along with the entire TBR chassis. This should be a solid build.
