Casual STK-M “Laserpointer Shotgun” (3xLPL, 1xLBX20, STD300)
Thread in 'Misery' started by Lorgot, Sep 9, 2019.
  1. Lorgot
    Lorgot Advanced Member
    403
    72
    Range synergy and similar cool down along with a combination of pinpoint and crit seeking make for a deadly combo.
    Armor is a little out of my comfort zone, but did what must be done for slot/ton perfection, take out a heat sink if it suits your fancy for armor
  2. CarloArmato
    I thought there was a cooldown quirk for that LBX, but that ain't the case.
    In my mind, if you are going to fully exploit the STD and shield with the right side, due to the high cooldown of both LBX/AC20 (4s) vs LPL (~3.5s if we consider both laser duration quirk and laser duration skills), that half second of difference is quite huge when compared to LL. You are going to lose some damage application, but cooldown will be almost identical (3.1s + 0.9s considering both laser duration quirk and skills) plus you are saving 6 ton for additional armor and lasers for the alpha god.
    You can either drop with 3xLL, LBX20, 2xML but only 2 ton of LBX20 ammo (maxed ammo skils are mandatory):
    ... or, if you don't like the longer ML cooldown, downgrade to 2xERSL and add that 3rd ton of LBX20 ammo
    Also, please note that my version have very similar maximum DPS, but better sustained DPS and higher alpha strike... So unless damage application/laser duration is REALLY important (i.e. you like to prove to other light pilots that you shouldn't be messed with) it does look like a solid build.
    Lorgot likes this.
  3. Lorgot
    403
    72
