So like, Rocket Launchers On a Stalker With a LPL in the CT With a STD engine Sounds like a horror/sci-fi crossover to me. Move armor from the arms to the legs if you like, or you can drop to a 280 engine and max the armor with no other loss to DHS or anything. I thought the speed might be worth-while on a brawler such as this though, and it's not like there's any ammo in the legs or anything. Fire the LPLs in one group, the MLs in another, and chain-fire the RLs when you find a juicy target to "insta-kill" with your 200-damage missile "alpha" - mind the minimum range on the RLs of course. Here's an alternative with four LPLs, all in the arms, and a single ML in the center. But this one you can't alpha constantly the way you can with the original, due to ghost heat. It also uses a LE instead of a STD, so no true zombie-potential. And it has 2 fewer DHS, which will make a considerable difference to your sustained DPS in the long run.
