I've been playing around with this build... High Armor and crazy damage if you can get up close! Enjoy and tell me whatcha think! -RoflRAWR
Here is what I find wrong with your build. It is a pure brawler, with no med range hit. one of your SRM6's come out as 2x2x2, not as a whole group, and who has time to track that? to fix these issues, I've run it as such. I still would give this build 3-5, since I think your OP build can do well. and lastly, welcome to the forum.
Heat is manageable, as long as you aren't on a planet over 80c. Then you have to play with a bit of caution... Going to live stream the spec for awhile tonight and then highlight the video afterwards. Feel free to watch: I'll post the highlight video afterwards
The stream from earlier: Heat issues aren't that bad once you do a 2 - 3 set up and don't alpha all of them at once.
not to shabby mate. I would recommend learning the firing times of all the weapons, so you know when to TT away and to your target.
this is what im running, you can modify it by dropping the ams taking half a ton of armor off the legs to make the 4s on the arms 6s. Like an earlier post said once you stagger fire it the heats managable. My fire groups are: 1 Both lasers 2 arm srms 3 torso srms 4 stagger fire lasers I just avoid using the lasers at close range and im ok on heat, also i dont fire both srm groups at once often
