With the new Large Laser weapon grouping, my 3F Sagittaire build was in need of a redesign. This simplified load-out should translate neatly onto all Stalker chassis, but don't quote me on that. The build follows as true to the stock Sagittaire load-out as possible. An ERPPC provides good long range fire-power, backed up at shorter ranges by pairs of LPLas and MLas. Although a standard Sagittaire has MPLas, the extra range and better synergy when paired with LPLas meant that MLas were the more logical choice. The BAP module is something of a crit filler, though with the builds intended role as a brawler, being able to burst the ECM bubble in support of team-mates could prove useful. STK-5M Sagittaire MKII Alternate A: Swapping out the two LPLas for standard LLas and shaving off half a ton of armour frees up sufficient tonnage to install a maximum rated engine and a further two DHS.
You have a lot of cooling for a laser boat. 4-5 stars for this build, as you have a weapon for every range.
