STK-5M Hybrid ( 2x(ER)LLas, 3x MLas, 2x LRM10, 2x SRM4, STD275)
Thread in 'STK-5M' started by bart2o, Dec 4, 2013.
  1. bart2o
    bart2o Well-Known Member
    189
    You can engage pretty much everything at any range/out of LoS with decent damage.
    You can snipe enemies at long range with LLas + LRM support fire.
    You can peek out of cover to throw an LRM salvo or/with a burst of M/LLas point damage.
    Exchange LRM for SRM at short range.
    It runs quite hot and is a bit confusing at start due to 4 weapon groups. Once you understand what works at what range it gets quite easy to use. I've ran my fair share of 800+ damage games with decent amount of kills, between 450-600 is quite regular if that's any indication of viability.
  2. The Verge
    -1% heat for +engine size and +1ton of ammo+.5 ton of armor>OP
