STK-5M Hellstreak Brawler (2x LPLas, 3x MLas, 5x SSRM2, BAP, STD310)
Thread in 'STK-5M' started by TheWatchman, May 24, 2013.
  1. TheWatchman
    TheWatchman Dispossessed
    Its taken me a while to get around to a 5M build. Initially I was thinking of a support build, but for the sake of my sanity opted to design a brawler instead. It mimics my Misery brawler build for Energy weapon placement, with the two LPLas mounted in the right arm and the three MLas in the left arm and CT slots. I had planned to make the build more symmetrical, but the packaging wouldn't quite work. An AMS system didn't fit either. The five streak packs provide good, low-heat back-up to the lasers and along with the Beagle Active Probe gives the build a excellent defence against ECM builds and lights. A ton of ammo for each launcher provides a huge amount of combat persistence. As the longest ranged weapon in the build has an optimal range of only 300 metres, having the maximum rated engine allows you to close the gap as quickly as possible.
  2. skribs
    skribs Min-Max Maniac
    1,690
    I don't go through even 400 rounds a match in my heart punch build. Shouldn't be too hard to fit AMS on by dropping a ton of ammo and playing around with other stuff.
  3. TheWatchman
    Yeah, I know. Couldn't quite see the wood for the trees, or something like that. Anyway, I tweaked it a bit and everything seems to fit:
