STK-5M Assault Brawler (LPLas, 4xMLas, 2xSRM6, 3xSRM4, AMS, STD270)
Thread in 'STK-5M' started by TheWatchman, Jul 20, 2013.
  1. TheWatchman
    TheWatchman Dispossessed
    Taking advantage of the recent SRM damage buff, this build mounts the second highest number of SRM packs possible after an A1 Catapult, along with considerable laser armament. Six tons of ammo allows for 25 salvoes of 24 missiles. Four MLas and a single LPLas pack a considerable punch up close and with the LPLas mounted in the centre torso, this is an effective zombie build. Armour rating is good, which is a bonus as with only an Standard 270 engine the build is quite slow.
  2. The Verge
    I just Barely managed to fit a STD 300 in this build. I did have to reduce the leg armor, but it should be good enough(hopes and dreams..).
    ATM, just a concept
    Your build, however, is great. 5-5
  3. Blagg Zear
    Hi there, this is something very close to my Terminator build. The differences are apparently, you have four MLas instead of my dual LLas and an additional SRM4 Pod. And besides you dont use Endo to have enough Slots for more DHS. Well at first glance your build looks superior by the super high Firepower. In fact I initially came to a similar build with five Lasers and five SRM.Pods, but then I dropped the fifth Missile Pod because of the limited Narc.Tube and changed the quad Mlas to LLas for better Range Attacks and better Heat Efficiency by almost equal Damage output. What i really miss in your Build is Artemis, which i definitely always use with SRM6 because of the wide spread. So in the End your build is limited in Range and if you come to Attack Range you have to decide whether to shoot all SRMs or the Lasers. Using all of them would push your Heat Level very fast to the Limit. To deal focused Damage on particular Body parts you are forced to use the Lasers instead of the SRMs because of the less effective Shotgun.Effect. And one of your Missile Pods shoots in a stream of single missiles. With all these flaws I give your build 4 of 5 stars, and thats only because of the overwhelming Alpha.Firepower.
    Blagg
  4. TheWatchman
    Assault Brawler Mk. II
    Similar to the original build, but with some mid-ranged ability. Still a zombie build, though not to quite the same degree as before. All I need to do now is make it a bit faster.
