STK-4N "Terminator" (4x LL, 2x SRM6+A, 2x MLas, ST300)
Thread in 'STK-4N' started by Blagg Zear, Jul 22, 2013.
  1. Blagg Zear
    Well, not my favorite Variant, but if i have to play this one then maybe definitely as Brawler, then i would build it like this. Very similar to some of my other Stalker Builds with Lasers+SRMs Combos.
    Blagg
  2. TheWatchman
    TheWatchman Dispossessed
    You've been busy! That's a lot of variants. The SRM damage buff has improved the weapons' standing in the overall arsenal of MWO. No longer merely a back-up weapon, they are now very effective as a stand alone weapons system. Here's my take on your original build:
  3. enileph
    Simple but cooler.
    Motörhead likes this.
  4. Motörhead
    It depends on how it feel ingame, not even elited I'm not overheating with 6 LLas and 20DHS and I don't even have 2x eff. But with 15 it will cool too slow for an assault maybe, once you reach high heat.
    TESTED
    those LL quirks are AMAZING! With quirks and modules they fire every 2 seconds @almost 600 range ! This makes the other 2 LLas in a 6 LLAS build redundant since they are low mount and when you are done firing both LLAS the other is charged again if you waited full burn time for max accuracy, and SRMs are better, given the also get 12,5% reduction ! now I have SRM6 cooldown modules and that's why I wanted to make an SRM6 version
    Anyway I'm using a slight mod of your build, works for me and the 15DHS would be too hot, won't bother testing. Since this mech has endo steel I'm partial to fill all slots, and AMS always helps on a big and slow mech
    In this match I killed a SPL firestarter A(full life) and a spider 2 vs 1 that was incredible, as I had both ct and sts cored, but I trew 2 alphas and legged them both lol the 2 more alphas to finish. Lots of luck involved too.
    I never thought I will have bought and liked a stalker 4N few months ago !
    EDIT
    runs so cool after elite that not filling all weapon slots felt like a waste, so I added 2 mlas too, I can use radar deprivation and advanced seismic now anyway.
    10 damage, 297 range and still -10% cooldown and heat, for only 6% heat when fired on an heat neutral map are better then AMS.
    Other then being and good sniper this has an alpha of 71,80 (provided you avoid LLAS GH) and can alpha 3 times in a row, now much distant from a WHK firepower while actually having more range with the main weapon (and shorter burn time, and much less cooldown, and much cooler!).
    When I get a STD310 I'll probably run a version with max engine, no mlas and no ams @2,5T of ammo, speed gets more and more important these days and even 2 km/h can make a difference.
    Vundar and enileph like this.
