STK-4N Stormhammer (4x PPC, STD300)
Thread in 'STK-4N' started by Cthulu Jr., Jun 9, 2013.
  1. Cthulu Jr.
    Cthulu Jr. Well-Known Member
    229
    My attempt at making a "supreme" Stalker PPC boat. Fast, well armored, powerful, heat efficient, and relatively cheap.
    I've also experimented with replacing the arm PPCs with ERPPCs-exactly the same as the basic build, except with a heat efficiency of 34%.
  2. Athariel
    Athariel Well-Known Member
    117
    I run an almost identical build with 2 x PPC and 2 x ER PPC no BAP and reduced leg armor for an extra heat sink slightly bigger engine.
    The build is still quite viable as with the heat stacking penalty PPC's are fired 2 + 2 to avoid the penalty. In pugs I prefer to run this build as 4 ER PPC are just too hot now.
    However I use 4 standard PPC on a 3F for 8 man drop decks as you have guaranteed support should anyone get within minimum range.
    Gameplay vid and thread linked below
    http://www.mechspecs.com/forum/index.php?topic=1907.0
  3. ArsenicForHealth
    ArsenicForHealth Junior Member
    49
