STK-4N "Pirate Standard" (4x LLas, 3x SSRM, BAP, AMS, STD310)
Thread in 'STK-4N' started by greenbeard, May 8, 2014.
  1. greenbeard
    greenbeard Active Member
    95
    The four large laser setup is pretty much the basis for my stalkers, period. It has been an absolute success so far. The cooling isn't spectacular, so I chainfire my lasers 80% of the time to keep cool, and never alpha unless it is absolutely needed.
  2. Blagg Zear
    Nice build you have created for the worst Stalker. Double LLas on each Wing can be devastating in Midrange Attacks. I'm just not sure if triple Streaks with 1t Ammo would be good enough as close range support Weaponsystem. I would maybe replace them for SRM4 Launchers since they are again very viable after the SRM Buff. :)
    EDIT: Btw. have you tried my Terminator Build?
    p.s. you should update your Build Name according to the Site Rules or Michael gonna kill you :p
  3. greenbeard
    95
    Stylistically I prefer SSRM's, but am getting the value of SRM4's much more after the buff so I'll give this a good run. That is a superior build, although I'm dropping a ton of ammo and throw on a TAG for extra bonus action.
  4. Michael
    I'll change the title on this one but from now on out you name 'em or I delete 'em. Your name is on The List (tm)
  5. greenbeard
    95
  6. greenbeard
    95
    Actually, this is very close to what my first build was, but with streaks (of course) and BAP.
  7. enileph
    4N is really not worth it, but you can try this ride.
    Anything your 4N can do, but better.
  8. greenbeard
    95
    Four large lasers and I'm good to go.
  9. Remarius
    Trying a very similar build at the moment to cater to the large laser 20% bonuses to range, cooldown and heat generation. Even the missiles have a 12.5% Cooldown bonus. Not comfortable yet with the potentially horrendous heat and I've been using paired arms and then the SRM 4's on my three main triggers, switching to chain on the SRM's if harassing/too hot.
  10. SFRM
    SFRM New Member
    [/QUOTE]
    I've been having good success with the 4N in this configuration. The mediums give me a bit more punch at range, and I found that it was very rare that I would be in a match where I needed more SRM ammo than I had on board. Either you are dead or the enemy team is if you are spending that much time that close to them.
