This is the build I arrived after playing my freshly re-bought Stalker 4N with the most obvious 6x LLas build initially. This build sacrifices some of the mid- / long range firepower the 6-LLas-build provides in favor of a much improved short range punch. The 5 LLas are absolutely sufficientt for a long- to mid-range engagement and the mech runs a lot cooler if cycling throgh 5 LLas instead of 6. Note that 2x SRM4 with a single ton of ammo can be exchanged directly with a 6th large laser, so there's quite some inherent flexibility. I for my part deciced that the weight of the 6th LLas was better spent for the massive short range punch double SRM4s provide, as those mean a salvo worth of more than 16 damage should you be in an effective fighting range for the missiles. One ton of ammo runs dry quickly, so better be sure about your aiming and shots. Removing a DHS in favor of another ton of ammo should be pretty doable as well, but as it stands now the mech runs very nice for me at the moment.
