Inspired by @Aylek : Mine : I prefer triple SRM4 for faster fire rate and spam, because it's a finishing weapon, and you can get +1 DHS and a bit higher speed, yes I've put a 305 to min/max but you can easily downgrade. The concepts are very similar and they are basically the same build, anyway.
Yeah, very close. You can skip one DHS because of the LLas quirks. I added an AMS for added survivability and am using the DHS in the arms for crit padding.
5/5, It's my build, and it even has my name, so what to say? Other than it'll stil be good even after the upcoming quirk changes on May 19, 2015?
Almost I actually think that we will see more SRMs and less LL after the new quirks, the low hardpoints might not be worth anymore with the added heat and reduced range.
Using 3xSRM4 instead of 2xSRM6+A. Probably just as accurate, but you get to add an extra ton of ammo and DHS. That said, the grouping of both SRM6+A in the body makes it easier to control. But yeah AMS would help.
