The least liked Stalker variant felt sad and lonely with only 22 builds since 2013. All his friends got new tech upgrades, but not for the poor 3H. Now, he takes revenge. LRM20 cooldown and heat generation reductions? Hells yeah! Artemis+Tag for quick lock-on LRMs? Allright! Capability of defending itself close range? Neat-O! Equipped with a sparkling new Light Engine? Wowzers! This mech could even be educational; it helps with getting used to taking your LRMs closer to the front line without feeling totally useless as you might do with a quad LRM15 mauler for instance. If you own this variant, give it another try
I like the idea to force someone to use something like this: you both have the double LRM20+A which is the best ghostheat-less combination to deal damage with indirect fire, and still has the short ranged weaponry of a medium sized mech to deal damage up close. It is mainly a LRM boat, but you can easily force it to be a second line pusher, because you can soften up earlier and finish off later. Not bad, I could consider buying one just4fun
