Still need to do some tweaking with it, the ER PPC is just too hot with this thing, even with the quirk; It's got quite a lot crammed into it already between the endo and ferrous installed, it needs two more DHS for better cooling. Though if you're not firing it consecutively, it might be fine for those still looking to use it in a sniper role. The ML cooldown might be useful for some though. And JUMPJETS!
ERPPC + 3 MLas works fine for me. So does LPLas + 3 MLas. The trick is to lower the engine size to a 300 as long ad basic skills aren't doubled.
It is ok. Only a fucking idiot would run stock loadout. You need to move around stuff to make it useful obviously. I think doing some armor renovation and an XL300 would do the trick nicely. If you think it is too hot then. For jump snipery actions you can do this: Remember that most likely you are not using both ML and ERPPC. If you like it hot you can go all out though
Think I'll just stick to a Jenner/RVN-3L hybrid... No way ERPPCs are usable, single LPL and three MLas seems a bit short ranged without speed tweak... (never mastered CDAs) Then again, there's always the triple lindy... Meh, we'll see with Beer Warriors tonight...
I went with ERLL and 3 MPLs. only got to run it on the new Caustic Valley and it was chaos while everyone figures the map out so I have no idea I it's going to end up working for me or not
