SNV-A "Boba Fat" (4xcATM12, 4xcMPL, cXL325)
Thread in 'SNV-A' started by Excalibaard, Jul 26, 2017.
  1. Excalibaard
    4,424
    980
    219
    Quintessential ATM-boat version. It's hot and powerful as you'd expect. Don't use lasers and ATMs at the same time unless ABSOLUTELY NECESSARY and don't alpha the ATMs, but fire 2 by 2/chainfire.
    Tollas669 and rinco like this.
  2. BobTheMad
    BobTheMad New Member
    Here's mine. Has over 1000 ATMs on board (with skill bonuses) with a Tag laser and 2 ERMLs for backup (also can use Heavy Med lasers too). Clan light active probe for faster locks.
    You can swap the ATM-9s for 12s, but generates a lot more heat. I find I actually do more damage with 2 each of 9/12 due to higher fire rate.
    invernomuto likes this.
  3. rinco
    rinco Well-Known Member
    I also lost the Endo, added some ammo, a DHS and a tag. But I decided to downgrade the lasers instead of the ATMs and also strip some leg armor...
  4. Excalibaard
    4,424
    980
    219
    I don't like sub-50 leg armor on an assault, especially with anklebiting piranhas in the waters. I also advise against 14 head armor, as 16 is necessary to survive dual gauss headshot (18 preferred against laser vom hitting your head for a few ticks).
    If removing endo for more DHS, I'd downgrade the engine and fit it as such:
    Also a remark about the other reply: Active probe does NOT improve lock time, it improves Targeting Info Time!
    https://www.mechspecs.com/resources/compact-equipment-and-utility-weapons-guide.32/
  5. Tollas669
    Tollas669 Active Member
    53
    I use mine like this if i remember correctly though some numbers maybe off. Though im thinking about loading it up with 12s instead soon.
