Since heavy larges sync up well with ermediums i thought why not. Since heat dissipation got buffed it cools back in the blink of an eye and thanks for standard engine you can still dish out some damage without speed reduction from st destruction. Since theres 2 slots left you can shave some armor off and squeeze a tc1 or even a lap or ap.
IMHO is not worth it. The main issue is that you need to expose your whole mech to alpha strike and coupled with long burn time, being not very agile and no ECM protection the outcome is more likely in favor of your opponent rather than this mech. To be compeltely fair, you can achieve an identical weapon loadout on a ECM hellbringer and despite being very close to overheat with a single alpha strike, due to heat dissipation and long cooldown you can alpha strike twice in a row. https://mech.nav-alpha.com/#23074d1d_HBR-PRIME
I have that Hellbringer with that loadout too already mastered but i thought if i can do the same on this mech then why not. Its not optimal but can side peek a bit with one arm and center lasers, albeit not optimally but it can.
