Casual SNS-B "Covid-45" (3xcLRM15+A, 1x cMPL, cTAG, cAP, cECM)
Thread in 'Sun Spider - Omni' started by Remover of Obstacles, Apr 27, 2020.
  1. Practice your social distancing and ammo hoarding skills.
    ECM makes you almost completely non-detectable.
    No fever here thanks to the locked 14 heat sinks and low heat draw even with 3 ghost heat from 3x LRM15s.
    I kind of like having the tag pull attention away from the important side of the mech. Especially with all that ammo in the torsos.
    If you have the Manul or some B arms, you can fit a MPL at the cost of two tons of ammo that you will probably never use. You should have extra heat most of the time. This is probably the better way to run this mech.
    krevLL likes this.
