Casual Skokomish "The Storm" (2xLPL, 1xMRM40, Masc, LFE325)
Thread in 'Skokomish' started by renzor51, Oct 9, 2019.
  1. renzor51
    renzor51 Advanced Member
    379
    Worth the extra tonnage of the LPL's instead of LL's? Hmm...
  2. Lorgot
    Lorgot Advanced Member
    403
    72
    If you got a masc, might as well get all the mileage you can out of it
    Also, you really don’t need 5 tons of ammo
  3. ShiverMeRivets
    190
    39
    While I am a fan of LPLs, LLs synergies better with MRM - both in range and duration. The shorter cycle time of the LPLs will often be wasted when waiting out the MRMs cooldown.
    I would tend to go with LLs and use tonnage to maybe squeeze in MRM30+20? Not a fan of MRM40 due to the larger spread and longer cooldown.
  4. Lorgot
    403
    72
    I already tried the 30+20mrm plus LL and it has a lower dps, plus I’d have to disagree on the range, firing the mrms at longer than 400 is a waste cause somebody’s bound to have ams, and unless they don’t move, your going to miss quite a bit more, so I’d say 350ish is more in line we’re you want to fire mrms anyways
  5. Lorgot
    403
    72
    Alternatively, slower, but much cooler
  6. Shock
    Shock Patron of the Underdog
    768
    321
    168
    I run something similar to 2xLL + MRM50 on a different variant of the Zeus. It's not great but it's not bad either
