Hello fellow Shadow hawk pilots. Its been awhile since any new SHD 5M builds were posted here so I figured I would put one up. While on the surface the armament looks light it is capable of dealing excellent damage from longer range. With its 300 engine and 5 JJ the thing is very mobile and can skirt around most maps easily. Pros: Good speed, armor, and jump height Surprisingly high damage Makes full use of quirks No heat issues, fire away on the hottest of maps. Cons: Ammo count is a bit light You may need your team to be meat shields on maps without good advantage points Alternative loadouts Drop down to 280XL to add mlas and slas or ammo
