SHD-2K "Dirty Bird" (2x LLas, 3x SRM4, 3x JJ, XL300)
Thread in 'SHD-2K' started by Solahma, Apr 24, 2014.
  1. Solahma
    With the added changes to HSR coming on the 29th and noticeable improvements on the public test servers 4/24, I decided to focus on a build that has a good compromise of SRMs and high-mounted LLas.
    Here is my initial test build:
    Designed to make good use of the high mounted energy points with the 2 LLas, but leave room for great speed and SRM availability. The SRM4s don't really need artemis and they got a slight buff recently (decreased cooldown time). The 3 jump jets will help carry this mech to good heights and over large obstacles to put an SRM alpha into mechs on the other side, or scrape with its LLas.
  2. enileph
    **4x SRM4 is invalid, change it back...**
    Almost had a wet dream from that.
    My version. A bit more hot and jumpy but no DHS in hand.
    Love how you can swap between SRM4 and SSRM2 easily.
  3. Vaeden
    Vaeden Active Member
    72
    I love this build! I tweaked it a bit ...
  4. Gasboy
    Gasboy Advanced Member
    291
    57
    I really enjoy this configuration. :)
  5. Excalibaard
    5,266
    A remark on the original build, If you have many jumpjets, you want max leg armor. It's common practice for many people nowadays to aim at the legs, and jumping up you'll give them an even easier shot at them. You need the armor there more than on your arms.
    STD engine variant that still runs decently fast.
    And an XL320 version (I usually use XL325, but that extra JJ is pretty nice)
  6. Gasboy
    291
    57
    Well, that and the extra fall damage they implemented.
  7. Solahma
    yeah, any of these builds in the light-medium weight classes should really equip the Shock Absorption modules. It helps A LOT to negate the fall damage, puts it back near what it used to be. It helps less for heavies and assaults though.
    @Subject, I agree with the legging thing for the most part. The nice think about the 2K is that you are generally jump-sniping over terrain with those extremely high shoulder hardpoints. You should have no excuse to show the enemy your legs, or the lower half of your torsos for that matter. Lights catching you is another matter though, hence me agreeing with your suggestion. This is probably why I prefer the PPC shoulder builds.
  8. Gasboy
    291
    57
    Starting to get 500+ damage games now with this. :D
  9. Gasboy
    291
    57
    I think I am going to start replacing the streaks in my other Shadowhawks with srm4s. It feels like a good short range hammer that even assault mechs notice. Usually limbs start to come off when I get to range to use them.
