SHD-2H "The Skirmisher" (1x LBX10, 3x SSRM2, 1x MLas, 2x MG, 2x JJ, BAP, XL300)
4 ratings
Thread in 'SHD-2H' started by Blagg Zear, Oct 15, 2013.
  1. lord_auriel
    lord_auriel Benefactor
    282
    the OP is amazing
    My variation - AMS is obligatory nowadays and helps the team a lot
    XL280 is as low as I would go on a SHD, ever, but it's okay
    EDIT
    Nekromanteia likes this.
  2. tong169
    tong169 Junior Member
    Great build. Only complaint is that the MGs' muzzle flash hurts my eyes. Going to thermal vision helps. Maybe they'll put in a quirk for that lol.
  3. Lugtor
    Lugtor New Member
    I just cant get this build to work for me. How do you fight with this thing? Like a Brawler, divebomber or skimming on max range ?
    The SDH just seems to be to big and easy to hit, while it does not deal enough dmg and feels totaly reliant on your teammates not being potatoes. since i farmed ages for this, i tried it out a lot and the best i could get were some games arround 450dmg, but mostly i got blown up after dealing ~200dmg.
    Then i stripped the mech, put in 2xSRM6, 1xSRM4, 1 ML, 1 AC5 which worked much better for me, getting reliable in the 400+dmg range, if I/Team does not screw up. So i dont know if this chassis is just not my style or the weaponry. Or the whole medium class, although i am quite successful with the Stormcrow.
    From my point of view I'd had to give this build 2 stars, but that seems not to be right.
  4. lord_auriel
    282
    this thing doesn't shine in the early stages of a battle... it's a 5 star build because it utilizes the mech's hardpoints in an optimal way..
    BUT it looks like the 2H is going to get AC5 quirks so I guess the go-to loadout will be some triple-ac-setup anyway
    try the 2x ac5, 1x ac2 variant with the xl255 engine. it's slow and lumbering but that doesn't matter since it will stay back and not run around
  5. Sjorpha
    Sjorpha Active Member
    Just fooled around with the concept and this is how I ended up.
  6. Soulcatcher
    Soulcatcher Junior Member
    I am running the XL 280 build with 1xLBX10, 2x MG, 3x SRM2 and 1x ML.
    What is the best way to group the firing buttons to keep Heat to a minimum while maximizing my Damage at Range?
  7. Excalibaard
    5,287
    Assuming a 3-button mouse, I'd group it like this:
    LMB: 2x MG + ML
    RMB: 3x SRM2 (Eventually chainfire them)
    3: LBX10
    Click once for ML only with minimal ammo waste, hold LMB for MG spam (a single ML produces very little heat), hold RMB for stream or frequent burst of missiles, press 3 for LBX once enemy is opened up.
  8. Trippton
    Trippton Active Member
    57
    With the recent changes to streaks (cooldown from 3.5 to 2.0) this thing is even more dangerous when picking off wounded targets. Great build and fun!
    Blagg Zear likes this.
  9. Hellhoundlover
    Hellhoundlover New Member
    The 2H is simply my favorite mech ever since i finished off a ppc highlander 1vs1 with just 2xMGs. It did have armor left, it only took about 5mins :D
    Been using this build from the start, currently it's evolved into this:
    (my Pilot rating is t2 just fyi)
  10. Gasboy
    Gasboy Advanced Member
    291
    57
    I put a variation of the OP's build on my 2H(P) a few years back and despite all the changes MWO has gon through, it still runs like a beast. :)
  11. Gasboy
    291
    57
    An awesome build.
  12. Nekromanteia
    Nekromanteia Benefactor
    45
    Omg OP was made 5 years ago, and this build still works like a charm! Recently just picked up this chassis variant and I'm having so much fun with it. Been alternating between Blagg's and Lord_Auriel's builds + using Excalibaard's weapon groupings to veektori **For some reason pressing Print Screen doesn't allow me to take screenshot? Is it because I've launched it via Nvidia GeForce Experience? Did 719 damage on 1st drop with 0 skill points**
    Blagg Zear and Excalibaard like this.
  13. Excalibaard
    5,287
    @Nekromanteia printscreen doesn't work with any full-screen application. best use steam function for screenshots, or change your settings to borderless window (may have impact on performance) :) Glad to hear it's working out for you!
  14. Nekromanteia
    45
    @Excalibaard Oh man borderless D:< Alright I'll try using the steam function for screenshots, thanks!
  15. ShiverMeRivets
    214
    49
    Been running this with the 3SRM4 and XL300 version. Very fun skirmisher - very much like a lighter Roughneck 1C, with the cannon on the wrong shoulder :)
  16. Gasboy
    291
    57
    Nono, the cannon is on the correct shoulder with the Shadow Hawks. Everything else is wrong. :p
