http://mwo.smurfy-net.de/mechlab#i=53&l=57a49041e679b4424f56f3659e440ceb318412db Fun to play...but that about it. Stick to a big guy and hope u can steal a kill..in rest make u money out of assist. Any suggestion will be greatly appreciated.
This build doesn't seem to add up. I've specced it, and with all the items/upgrades listed I can still max the armour (minus a few points to get a whole number) and have 3 tons free. May as well increase the engine size, add another ton of ammo (after freeing up the HS slot) and change it to an MPL. Like this: http://mwo.smurfy-net.de/mechlab#i=53&l=0646aa96b0a9261e39b3a0122bd6fbf557f2d0ae Cooling efficiency leaves a bit to be desired though. I'd drop the FF and get DHS, then you can stick with the XL170 engine and use the extra slots/tonnage for ammo or JJ.
Nope..i jest double check...the numbers are right and i don.t have space to add niddle. I jest check u link..u misunderstood..both arms have an AC/2 whit 1 T of ammo..so 2 AC/S and 2 Tons of Ammo
Ah yeah you're right, just looked at the build I linked to and I put an AC2 ammo in the left arm instead of an AC2! Here's an amended link to your build: http://mwo.smurfy-net.de/mechlab#i=53&l=57a49041e679b4424f56f3659e440ceb318412db I have changed something though: I put the AC2 ammo in the head and CT, that way it won't explode if your arms get taken off. I'd also consider dropping JJ (or at least some of them, keeping 1 or 2 for turning) to add more armour.
Meah...it's a spider...so after i make 2.5 mil whit it i.m going to sell it...and probably never build a spider again. To weak, everything a spider can do there is a mech already that can do it 2 times better.
They are weak, but they get max points for being creepy little weirdo's with either zero or massive firepower. I got third best score in a game yesterday with an AC/10 on mah arm. The K can mount 2 x AC/2s, an UA/C-5, AC/5, AC/10, LBX-10, LPL... just not all at once. Suffice to say, it's more fun that XPing up Hunchies
Lets face it, this build is insane. With that as the baseline assumption, I've made some "improvements." Strip out a JJ and the MLas for an XL200, and you can upgrade to the coveted DHS. Because you can never have enough Dakka. http://mwo.smurfy-net.de/mechlab#i=53&l=79e711496025d42ab0fb153a5524711e188d564e
My take... I have run my SDR-5K w/ 1x AC/2, but, TWOOOO??? MUST TRY! http://mwo.smurfy-net.de/mechlab#i=53&l=dd34eb2cf64f2510f3b88c9c0005a9294f046451
My variant, will try. http://mwo.smurfy-net.de/mechlab#i=53&l=f7c95411f9d19839c695b0c1703e181c94a51203
