Pretty fun build, i've been averaging a bit over 200 damage per match in it, which isn't spectacular, but the build is a lot of fun! Only 1 JJ (Please don't hate me), but nearly full armor. 4 Tons of ammo seems sufficient, I have yet to run out during a match.
Not bad but i would replace one ton of bullets by a MLas to have better defense against other Lights and if losing the Arm:
really funny build, ruining my great K/D I had with ERLLAS 4MG to run this, but totally worth it haha.
I have run this similar build for a while with about as much damage as a typical ERLLas & 4x MG build at the end of the match. Plays very different, for those with a crazy streak and a hatred of giant blue beams giving away your exact position... For some reason I get serious attention when they see an AC on a spider. It can't be because it's so dangerous, it must be due to how annoying you can be with this. Also the typical spider hate can't help. For the record when I see a max speed streakmando charging me I use the JJ and run the hell away. Like up a mountain. Streakmando is your kryptonite, only snipe them! Nothing else can really catch you other than a nasty ambush or a double gauss to the bird cage. Edit: I like putting the main gun in the left arm when possible, most pilots try to shoot out right arms on every spider they see regardless of chassis.
