SCR-C Crowblaster (2xcERPPC, 11xcERuL)
Thread in 'Stormcrow Omni Builds' started by ShooterMcGavin80, Jul 3, 2021.
  1. ShooterMcGavin80
    479
    73
    Hot and spicy, but with skills, very playable. 2xERPPC mounted above your cockpit makes for easy vertical peaking. The ERuL's give you a nice punch within brawling distances. Suggested skills:
    https://kitlaan.gitlab.io/mwoskill/...f00000000000000e86f770f000080a2211f#s=Weapons
    Can go agility instead of survival to taste. I'm on the fence of whether the extra armor and structure helps extend your life longer than the extra agility. But I'm going to go survival on this one, the agility is already pretty darn good.
  2. ShooterMcGavin80
    479
    73
    a little less than half skilled up pulled a good one...
    It was an overheat death... no arty strikes, only 1 cool shot.
    Stormcrow is not meta due to the hitboxes and lack of defensive quirks... but this can get some work done if you can use obstructions to get good close-range peaks.
