SCR-A "Natural 20" (10x cSPL, 3x cSRM4, TC1)
Thread in 'Stormcrow Omni Builds' started by enileph, May 4, 2015.
  1. enileph
    This is how you feel when your roll a Nat20 for hitting someone in the back.
    Yes it does get a bit hot.
    Remember to fire the beans in left and right rather than alphaing, or you will burn.
    SRM for longer ranges, and when things are hot.
    You can core things pretty quickly, but heat is bad, so you need to go hit and run.
    Cooler version with *ONLY* 10x cSPL + 2x cSRM4
    Something hot, not worth it after quirk nerf.
  2. Technically, you could alpha this without shutdown. Once. Don't miss.
    Probably better off with the cooler and tigher grouping SRM4s.
  3. enileph
    SRM6 is too spread out.
    Well, you can alpha this also, after elite.
    I can see these builds being more common now.
    The neat it less of a problem cause your cooldown is longer anyways.
  4. That Dawg
    That Dawg Well-Known Member
    185
    40
    A variant that will be tested more closely, that top one...I was all like, whoooboy, they tried it and was all like whatheheatthrowwateronme
    this one is doable so far, not sure about CW
  5. I was thinking about trying this variant.
    Alpha (0 + 9 + 24 + 5.7 GH = 38.7)
    Twist (38.7 - 3.59 - 3.59 = 31.52)
    Alpha (31.52 + 38.7 = 70.2)
    Run and cool off (70.2 / 3.59 = 19.55 seconds)
    You are heat neutral with the SRM4s and close to it with one arm of SPLs.
  6. That Dawg
    185
    40
    ...8 small pulse..........seeing builds like this almost trick me into buying back my Nova...for the THIRD time...
