Career Ruralmech R60/60L - AC2+PPC Sniper
Thread in 'Urbanmech' started by Toastygawa, Nov 23, 2019.
  1. Toastygawa
    Toastygawa Active Member
    52
    It took me forever to get an Urbie assembled in my first campaign and career playthrough. Second career started me with an R60, and I had the same trouble as with the King Crab: Thing is too slow to bring that autocannon into combat soon enough. I found some success giving it a long range solution. Early career pilots miss more often than not, but at least this gets the mech shooting as it slowly enters the field.
    **Adjustments: Dropping armor and JJs lets you add an AC/5 in place of the AC/2 for greater damage, but at the cost of heat buildup. Adding another JJ does help with the slow nature of the Urbie.
    Also effective with LL and AC/5
    Pros: More survivable than stock, works with both the R60 and R60L, heat efficiency is actually higher by two ticks if not using JJs.
    Cons: No shield arm, JJs only really usable for gaining elevation.
    This build shown using standard equipment. Using + or ++ helps with damage output, but keep this mech at distance.
