Meme "Rocket Punch" (3x RL20, 1xERPPC, 2xRAC2, AMS, XL320)
Thread in 'ZEU-9S2' started by Zatz, Jul 30, 2021.
  1. Zatz
    Zatz New Member
    Was just messing around with the Zeus and thought of using the one-use rockets to have as a kind of one(ish)-punch "mech be gone" spray. Not the most optimized build, but I've found it fun.
  2. Excalibaard
    5,187
    Welcome!
    It's like the thanatos hero but a bit bigger :) rocket arm is fun if you don't like MRMs as much.
    I feel like the RAC2 + ERPPC is a bit of a weird combo, I'd either use the rockets as a closerange backup with HMGs and have 2 ERPPC as main weapons for decent long range build, or go for 2LPL with an autocannon for a more mid/close range build.
    In terms of optimization, AMS has a bit much ammo, and maybe try to mount a slightly bigger engine, XL is dangerous in an assault so you'd better either go for something like an XL350 (endo steel is better than ferro fibrous), or mount a light/standard engine to avoid being killed from a single side torso explosion.
