Meme RFL-IIC "PGI PLS" (2xcLPL, 2xcERLL, 3xcERML, TC1, cXL235)
Thread in 'RFL-IIC' started by CarloArmato, May 20, 2019.
  1. CarloArmato
    Have you ever wondered how the meta try-harders will exploit the +2 HSL LPL?
    Ghost heatless alpha strike that will barely overheat your mech even without skills...
    The only true downside is the lack of sustained DPS and overall range discrepancy, other than that it should be a valid meta mech even without full skills.
    EDIT: this is true only if the +2HSL can be applied with mixed weapons
  2. Kill2Blit
    Kill2Blit New Member
    ghost heat groups always use the lowest number in the group to determine when GH occurs. since the HSL quirk doesn't apply to the er large, this build will still GH after two large lasers. people will just run the 4 lpl tbh
  3. CarloArmato
    Yup, it does trigger ghost heat. Swapped tag from invasion to Meme
