QKD-5K Pew Pew QQ (6x MPLas, AMS, 5xJJ, XL360)
Thread in 'QKD-5K' started by BindMind, Jun 18, 2013.
  1. BindMind
    BindMind Advanced Member
    322
    Pewpewpewpewpew. ;)
  2. FuzzyBunny
    FuzzyBunny MechSpecs Addict
    Always Endo over FF, in this case both limits your DHS amount. XL350 over the XL360 to save a little tonnage. Max as many DHS as possible to sustain the incredible pulse heat wave.
  3. BindMind
    322
    Can't accept the Quickdraw without at least 3 JJ's. I'd much rather deal with the heat and gain hit-and-run potential than lose that massive jump.
    You also took out AMS, which I would never do since the LRM buff (unless you're a light, and even then...)
  4. Warchanter
    Warchanter Well-Known Member
    100
    Compromise? :cool:
  5. BindMind
    322
    ^I would play that one.
  6. Randomm
    Randomm Junior Member
    Make sure you pay for the Double Coolant shots -- 40K is not a lot of money and it can really save your butt.
  7. Deafro
    Deafro Junior Member
    40
    This is the mech that inspired me to create my variant "Workhorse". Instead of 6 MPLas, I ran 1 LPLas and 5 MLas. Both weapon loadouts had the same tonnage, do the same damage, but the LPLas MLas combo reaches out to 300m as opposed to 180m. I wanted to see if I could fit it into this design, but the ferro fib means I can't put in that last slot for the LPLas.
    Still a efficient build altogether, maybe this might give you that extra boost of range.
  8. dranozir
    6 Med pulse make the job.
