Was thinking of making this build to level with was wondering if I could get some tips on it from some of the more experienced builders out there
I'm not sure if you want to keep the XL Engine or the Endo Steel, but this build seems a bit more balanced and takes advantage of your tonnage. I know the Engine and Upgrades are expensive, so I thought I'd suggest this first. This build takes out the endo steel, so you have a few more slots for heat sinks. Also makes more room for an addtional jump jet and brings you to 42% efficiency as opposed to 31%. Hope this helps
first, your idea is great. I would run it as such. For your first reply, you could do this. You only have 4 tubes, so SRM4 should be enough. For your second build, You could have a much larger engine.
