QKD-5K "Fuego" (4xERLL, 2xERML, LE300)
Thread in 'QKD-5K' started by SweatyFalcon, Jul 31, 2017.
  1. SweatyFalcon
    SweatyFalcon New Member
    The Fuego is Laser vomit build that takes advantage of the laser oriented hard points and the large speed that the Quickdraw has to offer. The premise of the build and it's playstyle is simple, just use your mobility to reposition and then attack with your ranged LL's. These can strike from a fair distance, so use their plentiful range to it's fullest. Keep the firing groups to two and two in an attempt to avoid huge amounts of ghost heat, as this build lacks some serious heat dissapation.
