QKD-5K Energy Boat (6x MLas, 5x JJ, BAP, AMS, XL360)
Thread in 'QKD-5K' started by Xiomburg, Jan 4, 2014.
  1. Xiomburg
    Xiomburg Dispossessed
    Fast, 6 medium lasers, jump jets...it's a nice light killer.
  2. The Verge
    oh look, it's a fat Jenner. it's too greedy close range, and just enough speed to get INTO that range. Plus, you have your AMS ammo in the arm, which is just silly
    do this, pls.
  3. Xiomburg
    You are right, moved it to the head.
  4. Jay Z
    Jay Z Well-Known Member
    102
    It's a big, easy to hit Jenner going the speed of a medium so it's not a great build from the outset. At least it has more armour and gadgets (BAP, AMS, better JJ)
    I would drop the arm armour down to 34 so you can maximise all torso and head armour.
  5. Creovex
    Creovex Active Member
    84
    No pilot experience added in it and first several games were averaging 3-5 kills and 4 assists.
    WG1: 3x ML (Left Side Linked)
    WG2: 3x ML (Right Side Linked)
    Alpha Strike on Enemies backs = Awesomesauce
  6. The Verge
    Duplicate Builds Merged
  7. Creovex
    84
    Incorrect merge and reported.
  8. Durandal
    Seeing as your build is nearly identical, no, it's really not an incorrect merge. You have the same build minus BAP and plus FF, with a different engine. It's a variant on an existing build, and thus merged. Makes sense. Not picking on you, but we already have hundreds of builds...it's complex enough without having multiple threads for mechs that are nearly the same. If the weapon loadout had significantly changed, that would be one thing...but when it's so close to another version sans the engine/one upgrade, those threads can be merged and discussed together.
