I admit it, the new heat and range mod to LPLAS means I've tried them out on various builds. This build started out with PPC's instead and can do surprisingly well with LPLAS instead. Recommended role: Brawler, fast attack Modules: Target info gathering, 360 target retention, seismic sensors. Recommended playstyle: Use cover, sprint or jump past the enemy for a full broadside. If in the big brawl, open with a full blast to core a component and use the pulses to bring them down. Twist and jump all the time to protect that XL, speed is what you have going for you so use it to outmaneuver them.
Fantastic build. My absolute favorite at the moment. I'm running it slightly modified: Modules: LPL Range LPL Cooldown ML Range
This thing absolutely tears apart mechs that have been softened up, usually one alpha to core them...If not, the second one should, except for assaults perhaps.
