Phoenix Hawk 2 "GUNMAN" (2xSNPPC, ECM, 6xJJ, XL300) "Gunman" like bandit - man with two dangerous gun. Young cowboy of MWO, fast & saucy (pert). Hot on some maps, but very fun. Not cheap, because need upgrade standart structure to Endo-Steel, armor to Ferro Fibrous, heat sink to Double HS. Also need buy XL300. My vision: PXH-2 "GUNMAN" SkillTree / with Sensors Tree
Nice vid Only one tip: you have both weapons on your arms, so why keep the "arm lock" activated? You will have an easier time getting "opporutnity shots" or following your targets, especially the fastest.
"Toggle arm lock" is probably the one you will like the most: I've replaced it with the previous "arm lock" (hold to disable) "shift" key binding.
