Wanted to make a bigger FS9-S. The punch of the 8 SPLs can cause some damage while still being low enough on the heat scale that you don't have to worry too much. Once you start getting high just fire different groups or chain fire till you cool down some. Once you have it skilled up I'm sure it'll run even better, maybe even swap out some DHS for BAP or a larger engine.
Was thinking about moving around the DHS/engine. Then I realize you can go with less DHS. Drop a couple and slap on FF, and you get near max engine of XL350. 4% heat decrease only for 10mph, a good trade. You are still waaaay cool at 40%.
I think with the arm armour buffs it recently got, the penis fawk is becoming a viable (and fun) option, especially with the ridiculous speeds you can get. Got some open mech bays with their name on it.
5/5, No ghost heat on SPLs, 28DMG alpha every 2.5 seconds or so. Very mobile, which makes it pretty threatening in Solaris 2V2, though 1V1 you may have problems against biggest alphas from ammo-based builds. I bought it specifically to have some fast laervom in solaris and it hasn't disappointed so far,
