PNT-8Z "All the lasers" (3x LLas, 2x JJ XL225)
4.5/5,
Thread in 'PNT-8Z' started by surus, Feb 17, 2015.
  1. surus
    surus New Member
    The first test runs seemed promising. With no GH on three LL I have one button bound to alpha and the second one has them all on chainfire.
    22y and B0ilz like this.
  2. B0ilz
    B0ilz Well-Known Member
    210
    62
    God, this is worse than the Raven Laser Chicken. I LOVE IT. :rolleyes:
  3. Durandal
    691
    Ha, the same build works on the 9R too, even with different (less specialized) quirks for this build. Fun build ;)
  4. Durandal
    691
    This build desperately needs double basics. You can get about 3 alphas off before you overheat, but it works much better if you can sit back and snipe. Go make friends with a Kit Fox or 3L as they snipe ;)
  5. 22y
    22y New Member
    OP's build with an XL235, but only 1JJ.
  6. Durandal
    691
    After having LOTS of heat issues, I finally just re-did the build and went 3L style:
    The fast cooldown and burn time actually makes this work just as well as the Superchicken sniper build, though the location of the hardpoints is less ideal. Still, it works. Using a LLas range and cooldown module, you can get out a lot of fire, and overall I've been doing better DPS/damage in matches since I take a long time to get hot. Recommend dropping the third laser and using speed, since you need as much heat management as you can get. Might try 3 laser again with double basics, but sticking with this until then.
  7. surus
    surus New Member
    I still keep on playing with the three large lasers, but the heat is problem. I'm actually very surprised how durable the right arm is. It is large with the three LLasers but compared to the mechs size it's not suffering from the Mist Lynx steroid arms problem.
  8. enileph
    I still prefer the 3x LL version... cool shots...
    25% range is nice, though the 25% cooldown is moot due to heat.
  9. Lan
    Lan Mech Wrangler
    1,570
    Excellent loadout for this chassi to play as support for the main push, find a angle and carve the opposition.
  10. MightyBolamite
    MightyBolamite Junior Member
    I managed to get on and play my Panthers for the first time today.
    Got to this mech, tried this loadout.
    I had 1 match. In the short time I lived, I killed a King Crab by my lonesome, pinned two clanners and wasted so many of their LRMs. Then I got shot by a Hunchie with a 20... twice. Surprisingly useful mech.
    You just need to know how to play to your strengths.
  11. Durandal
    691
    I'd agree...the Panther isn't weak, but it does have limitations. I mentioned in another thread that it will never be a comp mech (no reason to take it versus a Raven or Firestarter in something like MRBC, at least the way things are now), but it is far from useless/DOA.
  12. Lan
    Lan Mech Wrangler
    1,570
    This really can hit and vanish, with 3x LLAS it's going to hurt. With range modules you can reach nigh on 1200m.
  13. PyckenZot
    This baby on the mountain in crimson bay,...
  14. Thiak
    Thiak Well-Known Member
    244
    my take, faster engine, 1JJ
  15. Excalibaard
    4,787
    1,058
    Great with the laser duration reduction and other energy quirks, using the 3 energy hardpoints optimally.
  16. anamiac
    anamiac Well-Known Member
    140
    44
    What if you ran 2 pulse lasers instead of 3 large lasers?
