Casual PIR-CI "Piranha Colada" (5xcHSL, 6xcMG, cXL180)
Thread in 'Cipher' started by CarloArmato, Mar 23, 2018.
  1. CarloArmato
    1,926
    577
    Nice alfa strike, decent DPS and mediocre crit chance compared to other piranhas.
    Compared to the PIR-1 meta (3xcHSL, 12xcMG) this build has more emphasis on the alfa strike and, consequently, needs more cooling (+1 DHS), so this build has a better chance to open the back of a mech (even if you can't focus a component properly) but halved MGs DPS and overall crit damage.
    If you don't mind having additional armor on arms (IMHO you should, since they can soak up damage and maybe even save you once from pinpoint weapons), strip them and add another half ton of ammo.
  2. CarloArmato
    1,926
    577
    OP mech is OP
    1100 damage on Caustic Valley and around 30 skillpoints spent only in firepower and ammo.
    [​IMG] [​IMG] [​IMG]
  3. Guyver
    Guyver New Member
    the most op thing i ever played.
    bit of help from frozen city buildings.
  4. Lorgot
    Lorgot Advanced Member
    403
    72
    Ranges line up pretty well, and should help keep up vs 12mg
  5. CarloArmato
    1,926
    577
    2 tons of ammo for 6 HMGs are few: it's only 48 seconds of dakka dakka, even with max ammo skills. By stripping some armor you can fit another half ton of ammo, so you will be able to reach to 1 minute of dakka.
    Lorgot likes this.
