The wet dream of any locust pilot: huge alpha strike with high mobility. You can use any other chassis with laser hardpoints on the side torsoes.
Well, I can confirm it works pretty damn well on the Arctic Cheetah, so I'm sure it works here. I actually ended up swapping to 1 heavy large 5 heavy smalls on the ACH, since I found I could keep more laser uptime than the heat with 2 allowed. That gave me an even more destructive alpha when I popped in for a close range backstab. Not sure which way you wanna roll it here, but I will tell you this: it's a lot hotter than that cooling efficiency number suggests.
