Casual PIR-B "Locust's wet dream" (2xcERLL, cXL180)
Thread in 'PIR-B' started by CarloArmato, Feb 4, 2018.
  1. CarloArmato
    Hot long range sniper and harasser. Be sure to max out any heat generation skills (heat gen, cool run and eventually heat containment) before attempting to use this build. I'm not sure this build could work in Invasion mode as a filler for your lance...
    Best part of this build is that is use both the equivalent version of an IS Light Engine and it mounts both weapons on the CT, so you can lose any side torso with no consequence for your alfa strike (but you will be slower and have worse heat dissipation).
    Do NOT poke when other assault mech with pin point weapons are actively looking for you or in your general direction: gausses and PPCs will kill you or cripple you from 1 (very lucky heavy gauss hit) to 4 strikes if you are lucky they will hit your arms first.
