PIR-3 - "The Chef" (7x cFlamer, 5x cHSL)
Thread in 'PIR-3' started by Purity The Kitty, Jan 31, 2018.
  1. Purity The Kitty
    Purity The Kitty Active Member
    84
    If you've seen my MWO Cooking Show streams, you know the chef.
  2. Purity The Kitty
    84
    This got nerfed into the ground, after the Solaris update. So far I've dropped 3 flamers for a ton of heat sinks and gone to 6 Smalls, but 4 Heavy Mediums works pretty well too.
  3. Shock
    876
    357
    Nerfed how? I thought flamers were only changed if you're actually in Solaris
  4. Excalibaard
    Flamers now have ghostheat if you mount more than 4.
    Here's an alternative:
    Overheat them with max non-ghostheat flamers, and do two HSL salvos in their ass, then cooldown for the rest of the match.
  5. Purity The Kitty
    84
    Hilariously I brought back the show last night and found that out the hard way. It's 100(!) ghost heat, when I tapped my 9 flamer version I instantly exploded (lol 12 internal structure on ct).
    What I actually started doing is running 6 HSLs (screw the ghost heat) and extra heat sinks, and I like it. 10 HSLs works, but you've got one shot then you need to fully disengage.
    I'll be straight honest, there is very little this does that chef viper doesn't do better now, since the viper just runs so much cooler.
    skribs likes this.
