1. Hi everyone!
  2. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
Funny PIR-2 "b33fy" (15xHSL, XL170)
1 rating
Discussion in 'PIR-2' started by Purity The Kitty, Jan 24, 2018.
  1. Purity The Kitty
    Purity The Kitty Active Member
    54
    Someone had to post this. It's stupid, but it actually works surprisingly well. You have 3 groups, and with good burn control generate no ghost heat. The alpha strike WILL kill you.
    Came up with this well in advance, but b33f was running it a lot last night. He somehow had a couple 1k+ games, but was mostly suiciding for instakills, because tiny dire star memes.
    Respect these, they're out there like mad right now and they can and will oneshot you.
  2. PanykButton
    PanykButton New Member
    Extremely fun build. You missed the engine size on your post title
    ...Alternate name: Fishstar
  3. Remover of Obstacles
    Remover of Obstacles Benefactor
    664
    242
    54
    The LOLs are real. 4 KMDD on Terra Therma in first match.
  4. Excalibaard
    Excalibaard ComStar - First Circuit Staff Member
    3,361
    617
    219
    This is the first time i believe in a build with 14% heat efficiency. I don't have piranha's but will be looking to pick them up for cbills
  5. Purity The Kitty
    54
    This might end up being the first mech pack I buy. I have just been reposting builds I have seen be effective among my friends and unit mates.
    In reality I am finding the 3 with 10 of these and 4 flamers to be the better mech as people start to test that. I am also liking the 1 with a heavy large, 2 flamers, and machine guns as a possible can opener, but I think when you get to big guns the arctic cheetah starts completely outclassing it.
  6. CarloArmato
    CarloArmato MechSpecs Addict
    591
    154
    This is the final form of the PIR-2 once you are nearly done skilling into heat generation and operations. It's the best unforgiving backstabber (you can literally one shot assaults), avoid ghost heat and overheat, which makes this build actually viable for single backstabs
    Anything fast will wreck you if he is smart enough to keep moving and spread the damage, plus you have bad heat dissipation compared to what you can generate.
    It can also be used to open the front armor, but it is risky since you have a very long burn and face time.
    Absolutely OP if used properly, but hard to use and not really viable if you can't sneak up on the enemy: you must always flank and avoid direct confrontation, you can't miss-click 2 weapon groups or you will overheat, more than often you better run away to cooldown even if you succesfully killed someone without being detected...
    Still, this is one of the builds that would actually need a nerf: despite being fun, there is no fun at all on the other side to get killed in nearly 2 seconds.
  7. CarloArmato
    591
    154
    In a nutshell, this. #worthit #neverforget
    Falconium and Excalibaard like this.
  8. Falconium
    1,484
    450
    @CarloArmato I absolutely LOVE that you have the Jack-o-lantern cockpit items in this thing. So perfect!
    CarloArmato likes this.
  9. CarloArmato
    591
    154
    400 dmg, 4 kills (3 solo) in Caustic Valley. Good luck achieving 1000+ damage with this build, but it's still a killer.
    Enjoy the flanking and backstabs.
  10. Falconium
    1,484
    450
    Great run there, Carlo. Gotta say, the way your team-mates walk in front of your shots like that, forcing you to turn away or do all that team-damage . . . painful how the pugs can cost you so much heat, which is such a big deal!
    Those first two kills though? ABSOLUTELY PRICELESS!!!
    Somebody clip that
  11. CarloArmato
    591
    154
    OP mech confirmed. Can 1vs1 in Solaris by simply aiming for the CT, evade to cooldown if you don't succed.
  12. Shock
    Shock Benefactor
    514
    188
    53
    Looks nasty but I think the enemy pilot could have done a better job there.
  13. CarloArmato
    591
    154
    Don't say that too loud: I could be lucky to find someone with this build and heat scale himself to death due to misfiring :p
    Excalibaard and Falconium like this.
